Mystery Wire, Help!
Old Aug 24, 2009 | 08:17 PM
bowtieboy42's Avatar
Car: 89 Camaro
Engine: LB9
Axle/Gears: ?
Mystery Wire, Help!
Hey everyone. Me and a buddy cleaned up the top of my motor. We just finished putting everytbhing back together but we still have one mystery wire. It comes out of the stock harness and has a fusable link on it. Cant figure out where it goes.
Old Aug 24, 2009 | 08:21 PM
closer's Avatar
Car: 86' IROC-Z
Axle/Gears: 3 sumthin
Re: Mystery Wire, Help!
I just put my car back together today. That looks like the same connector that I hooked up from my EGR valve. But mine was on the passengers side of the dizzy and it didnt have a fuseible link in it. See if you have a wire coming off of the EGR base. That's my guess until I can look more tomorrow.
Old Aug 24, 2009 | 08:26 PM
Car: 89 Camaro
Engine: LB9
Axle/Gears: ?
Nothing on the EGR is unaccounted for. I'm so confused.
Old Aug 25, 2009 | 04:38 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
The only thing I can think of on that side with a single wire and that connector would be the O2 sensor.
Old Aug 25, 2009 | 07:08 PM
Pocket's Avatar
Car: 91 Trans Am
Wrong color for the O2 or the timing connector
Looks like it was added. Get a multimeter reading off it, 12v? 5v? IGN power? Ground?
Old Aug 25, 2009 | 08:59 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
dark green wire coming out at the back of the plenum... EGR Temperature switch
Old Aug 25, 2009 | 09:09 PM
PV9685's Avatar
Car: 89 Firebird Formula
Engine: 305 Vortec, Single-plane, 4 barrel
Transmission: T5, soon 700R4
Axle/Gears: 88 10 Bolt, Disc, Auburn, 3.23
+1
Definitely EGR temp wire. I can send you pictures, lol. Pull the plenum and have a peek
Old Aug 26, 2009 | 04:26 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
That could be. The later TPI's didn't have that.
Old Aug 26, 2009 | 11:48 AM
Chevy8588's Avatar
hey bowtieboy UPDATE YOUR PROFILE SO WE KNOW WHAT WE"RE DEALING WITH HERE! and yes the only single contact connector dark green wire on the harness is for the EGR temp sensor. judging from the pic, you probably broke the sensor. if so you have problems, discontinued part bud
Old Aug 27, 2009 | 12:11 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
+1 on the EGR.
Old Aug 27, 2009 | 03:20 AM
Car: 89 Camaro
Engine: LB9
Axle/Gears: ?
This may sound dumb, but is the sensor required for driving? Does the PCM pull any info from it?
I'll pull the plenum and tubes tomorrow and see what I cant see.
Thanks everyone!
Old Aug 27, 2009 | 11:39 AM
Chevy8588's Avatar
wont effect drivability, but will give you an engine light, and you may notice a decrease in MPG
Glowsock
Jan 9, 2017 04:06 PM
diana227vegas
Jul 8, 2016 12:27 AM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
