88 L98 Auto
Old Aug 26, 2009 | 02:39 PM
88Roc6spd's Avatar
88 L98 Auto
Hey everyone. I'm in the process of installing a T56 from a 95 camaro and was wondering if I can use the same starter that is on the car now? Thanks
Old Aug 26, 2009 | 04:50 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: 88 L98 Auto
i believe so
Old Aug 27, 2009 | 08:03 AM
rx8ss's Avatar
Car: 1987 Iroc Z28
Axle/Gears: 9 bolt
Re: 88 L98 Auto
If I remember right the LT1 uses a high torque mini starter and the nose is smaller and you may run into a clearance problem when bolting trans in with original starter still mounted.
Old Aug 27, 2009 | 01:47 PM
88Roc6spd's Avatar
Re: 88 L98 Auto
Hello...so I can still use the starter that is on my iroc now with the t56...but I'll have to unbolt it before I put the new trans in? If that's the case then it's no problem unbolting the starter. thanks
88Roc6spd's Avatar
Re: 88 L98 Auto
Old Aug 27, 2009 | 02:53 PM
rx8ss's Avatar
Car: 1987 Iroc Z28
Axle/Gears: 9 bolt
Re: 88 L98 Auto
It depends on the starter you have. There are a lot of variations of the starters used on SBC's. I would remove it before bolting up the trans. Once the trans is installed try the starter, it will not fit all the way in where it belongs if the nose is to large. I just went and got a LT1 starter and was done with it.
Linson
Oct 24, 2025 02:00 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
FormulasOnly
Jul 23, 2018 08:47 AM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
