code 43, need help (VIDEO)
Old Aug 24, 2009 | 10:20 PM
camaronut396's Avatar
Car: 1989 Iroc-z Camaro
Engine: Procharged 383 Holley Stealth Ram
Transmission: Soon to be ATI TH400/Borg Warner t5
Axle/Gears: Moser M9 4.86
i need help, early in the morning my car wont stay running, and i am getting a code 43, once it gets warmer in the day it will start right up. i am thinking its the knock sensor. i have a 1989 camaro with a 1991 350 tuned port swap i did. let me know what everyone thinks.. thanks
http://www.youtube.com/watch?v=Cva_D4NGYFU
here is me recording what it was doing this morning. the last time i start it, i try reving it to keep it running, but it just falls on its face..
Old Aug 29, 2009 | 07:21 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: code 43, need help (VIDEO)
I was getting code 43 with a bad MAF. You might be needing to get the EST (under the distributor cap) checked. After that, and if that doesn't solve the problem, check a wire diagram and see what else is in that circuit. Good luck!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Falcon50
Aug 22, 2020 03:26 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
