Engine Idles funny!
Old Aug 26, 2009 | 08:35 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
Engine Idles funny!
Got an '88 Camaro with a 305 TPI. Sometimes when I first start my car the engine jumps from about 1000 R.P.M. to almost dying, then jumps back up again. It doesn't do this all the time but it does happen every so often. Installed new high pressure fuel pump not long ago, but it did this before that as well. Any suggestions would be greatly appreciated.
Old Aug 28, 2009 | 10:00 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Engine Idles funny!
Check your EGR valve for proper operation. I find the EGR valve is the number one cause of a surging idle.
Old Aug 29, 2009 | 05:49 PM
3rdgenred's Avatar
Car: 6.7 Powerstroke
Would you still think its the egr valve even if when you start your car its idles at 1000 rpm for about a minute then comes down to normal operating range (650-600)?
Old Aug 30, 2009 | 11:07 AM
Engine: 350 S/B
Mine does the same thing.
Old Aug 31, 2009 | 12:35 AM
Yes i still thing the egr would be my top guess.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
