Help! Temp. Sending unit location?
Old Aug 31, 2009 | 05:27 PM
Sexonfire14's Avatar
Car: 88 GTA
Engine: 350 tpi
Can anyone post a pic of where the temp. Sending unit is located?
I have an 88 gta. 350 tpi. I already tried the drivers side head. But i cant
Seem to find anything. Thanks.
Old Sep 2, 2009 | 12:30 PM
iroc_patron's Avatar
Re: Help! Temp. Sending unit location?
Someone correct me if I'm wrong, but I believe its on the driver's side head between 1 and 3. I think its a single wire and kind of tucked below the exhaust manifold, so you probably won't see it unless you get your head down there or feel for it.
Old Sep 2, 2009 | 05:27 PM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
You are correct, it is on the driver's side b/w 1 and 3. On the passenger b/w 6 and 8 is the cool fan switch.
Old Sep 2, 2009 | 06:42 PM
Car: 88 GTA
Engine: 350 tpi
Thanks guys. Appreciate it.
Old Sep 9, 2009 | 04:34 PM
Car: 88 GTA
Engine: 350 tpi
So i found the sender, but theres no wire.
Where would i plug in the other side of the wire?
Old Sep 9, 2009 | 07:53 PM
The wire is going to come out of one of the harnesses. On my '87 Iroc the wire comes out of the harness on top of the a/c compressor, but the accessories were set up weird in '87. On yours I think the alt. is on that side. Might just check around the nearby harnesses to see if you find a loose wire without a home. Maybe somebody with the same year can trace it back and let you know specifically where to look.
Old Sep 9, 2009 | 08:24 PM
Car: 88 GTA
Engine: 350 tpi
Yea ill look for it. Thanks.
86CamaroDan
Sep 29, 2015 10:08 PM
Gunsbee
Sep 7, 2015 07:10 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
tonys91rs
Sep 2, 2015 07:07 PM
