Anybody know what this is?
I was getting ready to do a tune-up on my 91'Z (5.7) and noticed this!
The "cone" (green arrow) looks as though it should connect to the hose (red arrow) in pic #2. There is also a nipple (yellow arrow) that comes out of the hose right before the "cone" that does not appear to go to anything.
I have completed the tune-up, but the car lacks some serious power. The same problem I had before the tune. It idles better and smoother but its like the car shifts into neutral about 40mph and will not increase in speed. The trans has been slipping for a while but as long as the fluid level is up the slip is minimal. I also replaced the fuel filter.
Any suggestions? My wife says sell it
! It's a bit of a POS at the moment but I hope to change that. It also wants to stall out when it's in reverse when the throttle is depressed.
Thanks for any help!
! It's a bit of a POS at the moment but I hope to change that. It also wants to stall out when it's in reverse when the throttle is depressed.Thanks for any help!
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: Anybody know what this is?
that looks like a vacuum line.
for what, i have no idea.
definitely plug it back together though.
i believe that the yellow arrow should connect to the red arrow though, not green to red.
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
On mine it goes to a small check valve that then splits into two lines. If you need pics let me know.
The 90 degree hose seems like it wraps around the backside to the drivers fender and to the charcoal canister. The other one I didnt trace. Should be easy enough to find one at the boneyard
The T is a check valve. It controls when vacuum it available and when its not to whatever is downstream of it
You can buy new ones from any parts store for about $3. Look in the "HELP" section
Your idle sucks because of the vacuum leak. Port vacuum goes to I think the MAP? And then to the cruise unit
Car: '86MCLS/(RIP'90Bird)
Engine: 305/305
Transmission: 2004R/700R4
Axle/Gears: Stock/Stock
the one from the manifold goes to the top of the check valve, the one that comes from the hvac goes to the bottom of the valve and the nipple on the side from the distributor should actually go to the fpr I believe, not the distributor.
Engine: 305/305
I have to correct that, as RED_DRAGON said, red to yellow, and green to the fpr.
Car: 85 Camaro IROC
Engine: 5.7 TPI
i dont have that on my car so i was only guessing from what it looks like in the pics.
Engine: 305/305
the_kid, the check valve is broken up top, so the hose that has the broken piece is the hose that goes up top and the fpr to the available end. That is the easiest and best way to tell what the configuration is. Good luck.
1+
