long crank on cold start
Old Sep 11, 2009 | 04:57 PM
pthickett's Avatar
I have a 1991 camaro z28 305 tpi
when the car is cold, so the morning for example, it cranks for 3 or 4 seconds before starting. also I have noticed it idles straight away at 750rpm, while normally when its cold it will idle higher at between 1,000 and 1,200 until it warms up. So I am pretty sure a sensor has gone, but I have no idea which one, where it is, how easy it is to replace and where I can get one from.
Any ideas would be great!
Old Sep 11, 2009 | 06:03 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: long crank on cold start
Check your coolant temp sensor. The one the ECM uses.
Somebody correct me if i'm wrong but I believe it's the one on the front of the manifold.
There's a temperature vs resistance table somewhere on this site. At a true cold start you should measure the value for ambient temperature.
Old Sep 11, 2009 | 07:23 PM
pthickett's Avatar
Thanks for your help
If it is that sensor, would my fan still turn on? As far as I can tell, once the car is running the temperature acts completely as normal, so the thermostat is kicking in properly and the fan turns on when it get up high enough.
Old Sep 11, 2009 | 07:35 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
your fan could be being kicked on by the auxiliary fan switch, its basically a back up
Old Sep 11, 2009 | 07:55 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Completely different sensors.
You have 1 for the ECM, 1 for the gauge, and 1 for the secondary fan.
Old Sep 11, 2009 | 09:35 PM
pthickett's Avatar
Ok, so using my fantastic powers of deduction, if my gauge is working, and my fan is working, the ECM sensor must be the one needing attention?
Old Sep 12, 2009 | 08:04 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
It needs attention in the form of a checkup.
Ohm that bad boy and see if it lies to you.
If it's lying to you then it's lying to the ECM as well.
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Bryan F
Aug 18, 2015 02:28 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
