Ground wire for TPS and CTS.
Old Sep 15, 2009 | 07:47 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
For the longest time i have had issues with my TPS. checked and replaced everything and the problem still haunts me. Today I had a possible breakthrough. For the first time ever the trouble code 15 came up. 22 and 21 would come up all the time for the TPS but never 15 which is for the coolant temp. sensor. I check my wire diagram and they share a common ground to the computer. They are also spliced with the IAT sesnor. Does anyone know where the three come together? Also i was tugging one of the grounds, not very hard, and the TPS ground came unconnected from the TPS. would a loose ground at the TPS cause the code 15 when the ground is spliced with the TPS? sorry so long. any help is much appreciated. thanks.
Old Sep 15, 2009 | 08:09 PM
trueburton's Avatar
Re: Ground wire for TPS and CTS.
also i checked continuity by back probing the ECM ground wire D2 and then checking each sensors ground wire. they all tested ok. so there must be a loose connection in the splice that is good one minute and then next... it slips loose. any other ideas? thanks.
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
