new fuel pump not working
Old Sep 15, 2009 | 11:40 PM
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
i bought a fuel pump to put in my car that has never been run b4. I put in a tpi motor. i cut the tan wire and put a circuit tester on it and it is getting power when it should be priming.
im thinking it might be shorting out in the tank - how do i test this theory - and is it inside the pump or in the wires?
thanks
Old Sep 16, 2009 | 09:14 PM
soxbaseball's Avatar
Re: new fuel pump not working
you can send direct power to it thought the obd plug under the dash hook up a wire from the positive side of the battery and plug it into the far left side of the plug it cant remember if its the top or bottom but one of them will send power to the fuel pump u should hear it come on. its in the haynes manuel if you have one.
Old Sep 16, 2009 | 09:55 PM
witnlyn's Avatar
Car: 54 Chevy Sedan Delivery
Axle/Gears: 3.73 posi
make sure you have a good ground.
Old Sep 17, 2009 | 12:01 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
oilpressure switch check
Old Sep 18, 2009 | 01:40 AM
Car: CAMARO RS
i have done the direct power thing.
my question was how do i prove that the fuel pump is shorting out?
Old Sep 22, 2009 | 05:10 PM
witnlyn's Avatar
the fuel pump gets its ground from the black wire to chasis, check your ground. if ground is good and you have 12v to it I would say its bad.
Old Nov 1, 2009 | 05:16 PM
Car: CAMARO RS
the new pump was bad thanks guys
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
mustangman65_79
Apr 14, 2017 05:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
