tpi falling apart from corrsion
Old Sep 17, 2009 | 03:24 AM
TXFBODYGUY's Avatar
Car: 1986 I-ROC
Engine: TPI 305
Transmission: STOCK
Axle/Gears: STOCK
tried to change my thermostat and and the housing is falling apart then i found that the water ports on the bottom of the TB had collapsed into its self and had hole all in the bottom housing does any one know what would cause this and is it common by the way the car has sat since 95
Old Sep 17, 2009 | 06:47 AM
KnottyBuoyz's Avatar
Car: 87 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Not sure, gotta look it up
Re: tpi falling apart from corrsion
Are they all aluminum parts? Are they rotting from the inside out? If so it's likely something called "crevice corrosion". Quite common on aluminum and stainless steel parts that are deprived of oxygen. Stray current (short to body or engine) can hasten the process.
Old Sep 17, 2009 | 04:48 PM
TXFBODYGUY's Avatar
Car: 1986 I-ROC
Engine: TPI 305
Transmission: STOCK
Axle/Gears: STOCK
yup everything that has fallin apart has been aluminum parts and it is from the inside out
Old Sep 18, 2009 | 05:19 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
I would have to agree that it is what was previously posted...stray electrical hastening corrosion.
69 Six Pack
Oct 5, 2015 07:51 PM
E_S
Aug 29, 2015 04:09 AM
g.l.mos
Aug 22, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
