Plug N Play Injector? advice needed..
Old Sep 21, 2009 | 08:08 PM
1970 Buick's Avatar
Car: 1989 GTA
So I am in the market for new, higher performance injectors. I don't want to go too big, but I want a littlemore performance. What size, #, injector would you suggest for a mild bolt on 350. Also, what pressure should the fuel rails be at with your suggested injector. Believe me I have searched but am not really finding what I need. I don't drive it daily, just at the track and around town. Thanks Also, are LT1 injectors direct plug in in our tpi's?
Old Sep 21, 2009 | 10:09 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: Plug N Play Injector? advice needed..
Check out FIC,fuel injector connection.A lot of people have bought from them and are happy.They are even on ebay.Send them a message about your mods and they will suggest a size.Depending on your modsyou may not need new injecters unless your old ones are shot.I prolly wouldnt go higher than 24#/hr for a bolt on car
Old Sep 21, 2009 | 10:45 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
If you want plug n Play you need to stick with the stock 22 lb.
Old Sep 22, 2009 | 07:55 AM
1970 Buick's Avatar
Car: 1989 GTA
I found a OEM Standard Ignition 22lb set for sale. They were originally for a vette. Will these make any difference at all over my 19lb ones? Mine work fine as it is, but I am looking for a little more performance.
Old Sep 22, 2009 | 09:39 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
If you are a 350, you should have 22lb in it. A 305 has 19lb.
I bought some stock replacements from John at FIC. I talked to him several times, he test tried a few injectors in a setup he had on his work bench. Even with the bolt-ons I have, he said stock size was fine. I have yet to run these injectors as I am waiting on a local shop to get done with a part.
Old Sep 22, 2009 | 03:35 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Plus once you do change injectors you will need to have the chip retuned for that size injecter.You`re probably fine with bolt ons with the stock size unless yours are in need of being changed.
midge54
Sep 2, 2020 07:13 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 19, 2015 12:07 PM
Bryan F
Aug 18, 2015 02:28 PM
