How to tell difference
Old Sep 23, 2009 | 12:21 PM
devilish1's Avatar
Car: 88 T/A, 03 cobra
How to tell difference between 305 tpi and 350tpi? I'm been looking around for used 350's. Is there any external difference between the 2 that i can tell if it's truely a 350?
Old Sep 23, 2009 | 01:00 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Re: How to tell difference
Casting numbers on the block. They are located on the back of the block on on the driver's side. Some blocks (not sure from TPI) actually say 305 or 350 on the back too.
Other then that, I'm not sure. I know with a carbed small block, their is no other difference.. but now you are dealing with fuel injection so it might have some other signs.
Old Sep 23, 2009 | 01:01 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
the only dofference is the injectors.. also the corvettes fuel lines are on the other side of a camaro or firebird. pre 89 has a cold start valve that you do not want to use. 90 up have a map sensor and are speed density. early units are maf
Old Sep 23, 2009 | 01:02 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
are you talking about the engine or the tpi unit?
Old Sep 23, 2009 | 01:17 PM
devilish1's Avatar
I'm talking about the engine. This engine I'm chatting with the guy says it already out of car. I'll have to look for above casting as stated above. But always wondered if one was in a car what should I look for to tell the difference. Is there a casting book i can pick up to help decipher differences?
Old Sep 23, 2009 | 01:36 PM
Christal_Z28's Avatar
Car: 1992 Camaro Z28 Heritage Edition
Engine: 5.7L 350; check out my VGarage :-)
Transmission: 700-R4
All 305 TPI engines came from the factory with 19 lb injectors. All 350 TPI engines came from the factory with 22 lb injectors.
Old Sep 23, 2009 | 02:54 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
externally 305's and 350's look the same. There isn't a "looks bigger/looks smaller" on the blocks. Visually the only thing you have to go by is the casting numbers. If the engine is still in the 3rd gen, then you can check the vin number. If the 8th digit (IIRC) is a "F" its a 305 if its "8" its a 350. Someone might be able to verify that for me...
Old Sep 23, 2009 | 06:06 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
If it is 87 or newer block it will say 5.0L or 5.7L on the driver side where it mounts up to the transmission.
Old Sep 23, 2009 | 06:20 PM
Pocket's Avatar
Car: 91 Trans Am
And since Fbodys didnt get the 350 until 87, this works all of the time for 3rd gens
Old Sep 23, 2009 | 07:52 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Mine is an '88 vin 8 it's a 350. They put 5.7L on the rear bumper, but that don't guaranty that's what's under the hood.
Old Sep 23, 2009 | 08:15 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
If the VIN says "F" and you have a 350, it was put in there...and vice versa. The VIN is from factory correct of what motor it has unless someone changed it along the years. Basically agreeing with the above post...can't go by stickers and other easy to tamper with external badging :-p
I actually had a car with the VIN showing a 350 and pulled the motor because it had a knock...spun main bearing...and it had "5.0" cast in the rear of the block by the distributor hole. Needless to say I was upset, but goes to show you, it can go both ways...up or down.
Old Sep 24, 2009 | 11:02 AM
devilish1's Avatar
Exactly the reason why i want to know what i'm buying. Yrs ago I bought a 2nd gen camaro with a "350" in it come to find out it was a 267 V8. If you guys are saying the 350tpi motor is stamped as such(350) on the back I'll look there thanks.
Old Sep 24, 2009 | 05:44 PM
Pocket's Avatar
Car: 91 Trans Am
It will say 5.7L or 5.0L, not 350
This trend is still in effect even with GEN III/IV engines
69GTOby
Apr 18, 2016 02:34 PM
scottmoyer
Sep 20, 2015 11:54 AM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
