thoddle body
Old Sep 24, 2009 | 09:39 PM
bigbadrat's Avatar
thoddle body
ok i have a 92 Z28 with the tpi 305.i have a 86 corvette 350 throddle body that i want to see if i can use it on the 305.will it work or will it cause me problems?i know it has a bigger cfm bore but will it choke my motor or give it alittle more power?
Old Sep 25, 2009 | 07:01 AM
S10Wildside's Avatar
Re: thoddle body
ALL 85-92 TPI throttle bodies are 48mm, so the Corvette throttle body (unless it has been ported) is no bigger than your current throttle body.
The other problem is the throttle linkage will be different.
On a stock engine, you're throwing away money on a larger throttle body.
Old Sep 25, 2009 | 10:38 PM
bigbadrat's Avatar
Re: thoddle body
well the openings r bigger then my stock 305.the linkage looks the same as well.so ur saying that it wouldnt make a differance?
Old Oct 1, 2009 | 03:17 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: thoddle body
Obviously not a stock 48mm TB
If the linkage is the same it is not off a 86; late models TB have a quadrant ( groove ) the cable sits in whereas the early ones just have a stud the end of the cable fits to.
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Kenwood
Sep 4, 2015 05:50 PM
