New to TPI and some concerns
Old Oct 7, 2009 | 09:52 PM
  #51
Hulkamania's Avatar
Car: 1988 Camaro Iroc Z
Engine: 5.7
Axle/Gears: 2.77
Re: New to TPI and some concerns
Well I put the fuse in and it didnt blow so Im assuming theres no short!
Old Oct 7, 2009 | 10:39 PM
  #52
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
The injector may short when it gets warm from the motor. Let's see how it does.
Old Oct 8, 2009 | 02:08 AM
  #53
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
It won't blow the fuse.If the ECM see low injector resistance it will shut the injectors down to protect itself.
Try FIC for new injectors.Good pricing and rave feedback
Old Oct 8, 2009 | 11:15 AM
  #54
Hulkamania's Avatar
Engine: 5.7
Axle/Gears: 2.77
After replacing the fuse last night in the car, I went out this morning car started right up just fine and it was colder last night than the night before. Drove to work, got colder today and is drizzly out. Got off of work and go out expecting it to crank over and over and over and it fires right up. Im hoping it WAS the fuse. However this doesnt prove to be what could have been the problem the days it did this when it was 70 degrees correct?
Old Oct 9, 2009 | 11:26 AM
  #55
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Shhhh.... silence brother. The gods of third gen have determined that you have put forth enough time and effort into resolving your problem that they have retrieved the gremlins from your TPI.. Be happy and ride unto the next challenge.
billybob6110
Sep 24, 2016 09:50 AM
formula1lle
Jan 29, 2016 10:56 AM
87iroctheo
Wheels and Tires
Sep 2, 2015 03:29 AM
someone972
Aug 30, 2015 12:52 AM
Sanjay
Aug 12, 2015 03:41 PM
