no fuel or spark
Old Sep 28, 2009 | 05:57 PM
davidGTA's Avatar
no fuel or spark
car is a 89 350 tpi, stock.
the car would not want to start somedays and fire right up the next and run great. went on for about 3 weeks then just died. i diagnosed it to no spark or fuel, i get fuel to the fuel rail but the injectors are not spraying(injectors are new bosch 3's with not even 3K miles on them). i replaced the distributor, coil, cap and rotor, still nothing.
wires are been checked countless times, they are on correctly, dizzy is where it needs to be, everything is pluged in and i see no damage to wires or connectors.
any one got any ideas???
Old Sep 28, 2009 | 06:39 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: no fuel or spark
VATS?
Old Sep 28, 2009 | 07:22 PM
davidGTA's Avatar
vats is by-passed on my car
Old Sep 29, 2009 | 03:46 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I say dist /ESC problem.The ECM has to see a signal from the dist while cranking to pulse the injectors.
It is the only thing I can think of that affects both fuel and spark at same time
The fact you say you have no spark leads me to think it is primarily ign related
http://www.corvettebuyers.com/c4vettes/l98.htm
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
