Low Idle with 5.0TPI 5spd
Old Oct 9, 2009 | 12:46 PM
metallica2000sm's Avatar
my 87 Iroc (51k miles) is idling at about 750 rpms. When she's cold (and I think even last summer when it was hot) would drop to 500rpms and then stall out.
I don't drive it much, so I'm thinking something is gumed up. Fuel filter was changed when I bought the car ~9 years ago, but less than 10k miles.
I changed the IAC valve yesterday, no help.
i really don't want to keep throwing parts at this, since it'll go back into storage here in a week or less.
i can't seem to convince myself it's the TPS as the throttle response is spot on, but the rpms (750) seems low to me?
I haven't driven it enough to remember what it normally was, all of my other cars are around 1,000.
Old Oct 9, 2009 | 01:49 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Re: Low Idle with 5.0TPI 5spd
My car idles at 650 fully warmed up. 900 it's first started. I'm betting the gas is bad since you barely drive it.
Old Oct 9, 2009 | 01:57 PM
I always keep Sta-bil in the gas.
Last summer I drove it enough to run a few tanks of good gas in it (always 93) and still had the same problem.
EGR? TPS?
Old Oct 9, 2009 | 05:47 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
clean the throttle body.
Old Oct 10, 2009 | 12:21 AM
StevenB L98/LS1's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 LS1
Possible bad pick up coil. You can test the TPS with out buying one first, you never know, tpi for some reason is very unexpected, you think its one thing.... when its actually the opposite, or another part. Mine idles at 1000-900 cold, and 600 rpm warm, 650 with the ac running.
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
Prodigious
Oct 4, 2015 11:20 PM
perZ
Aug 21, 2015 05:51 PM
perZ
Aug 15, 2015 01:17 PM
