TPI/ZZ4 Question
Old Oct 10, 2009 | 05:15 PM
reese_galmon's Avatar
Car: 1990 Firebird Formula 350
Transmission: 700-r4
TPI/ZZ4 Question
is the tpi system a good choice to install with ZZ4 heads and a zz4 com cam?
Old Oct 10, 2009 | 05:36 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TPI/ZZ4 Question
If your CR ends up the same. ZZ4 heads makes your engine the same as a Vette L98 TPI with alum heads.
ZZ4 cam worked great for me but likes intake mods; big tubes , ported plenum and base to get the best out of it
Old Oct 10, 2009 | 06:41 PM
what intake mods and parts do you recommend? My intake is stock right now
Old Oct 10, 2009 | 09:02 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As I listed .A aftermarket big tube setup or port your own
https://www.thirdgen.org/forums/post...545-post3.html
https://www.thirdgen.org/siameseport
http://www.cis.udel.edu/~davis/z28/buildup/plenum/
http://www.digitalcorvettes.com/foru...ead.php?t=1793
http://sethirdgen.org/TPIbase.htm
Old Oct 12, 2009 | 07:18 PM
You said if my CR is the same I'm a beginner at this can you explain this to me?
These are the heads I wanted to put on my 1990 Firebird 350
http://www.jegs.com/i/GM-Performance...oductId=955894
Old Oct 12, 2009 | 10:23 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
CR = Compression ratio .Heads have different sized chambers .
I believe L98 w/ iron heads is 64cc so the 58cc head will raise your compression somewhat
Also consider
Needs new intake to match but it is a big port intake saving you having to do the intake mods
Read https://www.thirdgen.org/forums/post...938-post3.html
http://www.summitracing.com/parts/NAL-12558060/
http://www.sdparts.com/product/E3817...nderHeads.aspx
or these @ $1000/ pr
http://www.summitracing.com/parts/TFS-30300001/
Old Oct 13, 2009 | 12:26 AM
thanks a lot I'm going to go with the trick flows
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
