Distributor suggestions
Old Oct 16, 2009 | 04:14 AM
white devil's Avatar
I recently scored a MSD pro billet, blaster 2, and 6AL setup from a friend, Unfortunately, I cannot use the dizzy on my 86 lb9 iroc...
What aftermarket dist do you guys recommend that wont cost me an arm and a leg? I have dome some searching, but its like parts companys have pretty much forgotton about the type of electronic advance hei I HAVE to run, and am having little or no luck finding anything.
Unless there is a way I can use this pro billet distributor... Thanks in advance.
Old Oct 16, 2009 | 07:38 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Distributor suggestions
Just run the 6al with any stock comp controlled HEI dist and buy a good HEI coil
Or you could always go to the later F-body remote coil dist setup and use the new coil you have
http://www.summitracing.com/search/P...0/?Ns=Rank|Asc
Old Oct 16, 2009 | 01:04 PM
Going to a later set up would require a ecm change correct? I had thought of that due to wanting to elminate the 9th injector.
Old Oct 16, 2009 | 06:55 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Going to a later set up would require a ecm change correct? .
No
'165 ECM used '86 - '89 with both type dist
There is a $15 adapter harness to convert the large plug on the HEI to small plug on remote coil dist.Have to run wires for remote coil
Can just get chip reprogrammed to take out CSI and add extra start up fuel through the injectors like the '89+ had
amargari
Nov 10, 2015 02:09 PM
camarohelp
Sep 22, 2015 03:19 PM
R13_Braz
Sep 18, 2015 05:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 6, 2015 03:05 PM
