396 Rotating Assembly
Old Oct 17, 2009 | 11:54 AM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
I've been looking at a new Rotating Assembly, I started a thread called 383 Breathing Issues, but it got filled with jibberish. I was looking at the 396 assembly from TPIS. Anyone familiar with it or the regular 383? Is there anything I should look out for before mating more cubes to the TPI setup???
Old Oct 17, 2009 | 07:26 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 396 Rotating Assembly
Plenty running TPI on 383's but the TPI was designed for the 305 and barely feeds a 350 let alone a 383+ Output will be severely limited by TPI ; depends what you are looking for.
Many would say
"why go to the added expense a 396 for increased HP and then strangle it with a TPI?"
396 is a lot more work in clearancing block for increased stroke and prob requires small base circle cam which is why 383 is more common
( cheaper ) option
Because 396 is less common the pistons are more expensive than 383 ones
Old Oct 23, 2009 | 09:17 AM
Do any of the members here who have the 383 TPI, have any feedback? Maybe such as yourself? I am just want to be sure of what I'm doing, I do not want to buy my rotating assembly only to be disappointed.
Old Nov 21, 2009 | 01:27 PM
Where are all the members with a 383 TPI setup?
Old Nov 21, 2009 | 11:29 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As noted most change the intake to optimise the benefits of the larger engine.
I used a well modified TPI ( SLP big tubes , ported plenum , siamised base ,30 lb injectors ,58mm TB ) on my new 383 to run it in with.
Killer bottom end and throttle response ;datalogs showed it reving past 6K but I know from the TPI graphs, power would not be increasing much over 5K
12.7 with A4 and 3.07 rear.
Swap intake to HSR , minor tune adjustment to spark advance ; ran 12.3 ( with a better tune would have gone faster )
Pick your poison
If you are not into big Hp and revs I say do it; you will blow any body off from the stop lights on torque alone IF you can get traction
Old Nov 27, 2009 | 08:07 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I Built a stroker 395 (maybe same as your 396) for my '87 IROCZ. Great torque, lots of fun to drive. However, I would not run a factory TPI unit on top of it. The 395 is a 30 thousands over 350 block with a 3.875" stroker crank. And as stated above the crank and pistons are less common. Check out my sig. Any specific questions?
Old Nov 28, 2009 | 07:12 AM
I have the Big Mouth Manifold, LTR's, 54mm Throttle Body. 30lbs injectors. I do not know much... Bless me with your knowledge.
Old Nov 28, 2009 | 07:19 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As I said if you are not into all out Hp then TPI will make killer bottom end engine but you will be leaving a lot on the table ( especially with extra expense of a 396 ) if you run a LTR style intake vs a HSR /SR / MR
Old Nov 28, 2009 | 07:44 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
SixseriesCSi: You will do very well with what you have. I must not be very smart because Orr in Pittsburgh is running in the 11s with a 383, and another guy has run my same ET with a 30 over 350 (which is a 355). So, I must be a bit challenged here.
For you, I like what you have. Install an adjustable fuel pressure regulator (AFPR) so that you can controll the fuel pressure to better dial in 12.8:1 AFR at WOT. Also, get a good fuel pressure gauge. Match port the LTR to the manifold and the plenum. You can even siamese (sp) the ports in the plenum. And open up the inlet end of the plenum to match the 54mm TB. If I remember correctly, there is a restriction just inside the plenum behind the TB. Grind some of that away and smooth it out. Now tune the ECM. You should be able to run in the 12s and have great torque on the bottom end. The car should be alot of fun to drive.
Old Nov 28, 2009 | 08:32 AM
AC's Avatar
AC
Car: Used to drive a camaro
Actually, Orr now runs a 400+ motor with twin turbos and is in the 9's...
My motor 2 seasons ago was a healthy 383 (nice cam, good Dart heads) and I ran the TPIS Bigmouth intake, SLP runners, 58mm TB and a heavily worked over upper plenum. The motor ran great but when I swapped over to a HSR it was certainly noticable where the car pulled in the upper RPM's compared to when the TPI style intake was bolted on.
Old Jun 3, 2010 | 01:38 PM
Any further thoughts and ideas??
Old Jun 3, 2010 | 10:57 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
It's all been laid out above.
You pick how YOU want your engine to run and choose the intake accordingly
Old Jun 5, 2010 | 10:11 AM
S10Wildside's Avatar
Here's a good read about a TPIS 396ci engine (LT1, but expect similar results from a SBC).
Originally Posted by Street Thunder Magazine
The final peak power figures were 477.9 ft.-
lbs. of torque and 533.5-horsepower
http://www.eficonnection.com/media/S...MayJun2010.pdf
This engine is in a 1985 Camaro.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
Dragonsys
Sep 25, 2015 03:51 PM
