How much HP or cubic inch and MAF handle?
Old Oct 18, 2009 | 05:45 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I was wondering if my stock(descreened/definned) MAF sensor is to small for my setup? Mods in sig
Old Oct 18, 2009 | 07:21 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: How much HP or cubic inch and MAF handle?
No. Stock MAF resolution is capped at 255 g/sec under transitional load, not at WOT....
.... and there's no way your hitting 255 g/sec at part throttle.
Old Oct 18, 2009 | 07:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I know of several running a 10 sec 434's with crappy slow '85 ECM that have stock MAF
http://forums.corvetteforum.com/1570898401-post6.html
http://forums.corvetteforum.com/1569461765-post9.html
Old Oct 19, 2009 | 12:23 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
The stock MAS is limited to 255 g/sec in all situations not just part throttle. Scan the car at WOT and see if the MAS hits the 255 g/sec reading. If it does you can compensate in the chip to keep the airfuel ratio safe but it will not be perfect.
Old Oct 19, 2009 | 12:56 PM
There is no need for resolution at WOT, that is the whole point. The ECM enters Alpha-N mode. Buick Grand Nationals are a good example of this, as they too are subjected to 255 g/sec, but at 15-psi of boost, the MAF is completely maxed out, yet fueling is still being provided for because of the preconfigured tune. This is why the MAF has no real cap to it, as the tuning needs to be done in the chip, and it will be perfect, after a couple of burns....
Hotrodboba400
Dec 10, 2019 07:07 PM
amargari
Nov 10, 2015 02:09 PM
86White_T/A305
Sep 21, 2015 05:28 PM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
