V6 Injectors
Old Oct 21, 2009 | 03:40 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
V6 Injectors
Do they ohm out the same as the V8 injectors? I know they flow less but is that done through a different pulse or a totally different injector? I need to check my injectors today and I can't find spec's for the v6 injectors anywhere. Any help is greatly appreciated guys.
Old Oct 21, 2009 | 08:02 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: V6 Injectors
your v6 has 6 19lb injectors.. They should ohm at 16 and I would replace them with Bosch 3's from FIC. www.fuelinjectorconnection.com
Old Oct 22, 2009 | 05:42 PM
Car: 92 RS
Engine: a slow one
Re: V6 Injectors
thanks irocuroc, exactly what i needed
if they end up being bad (picking up a multimeter after getting paid tommorow) I'll definitely get some bosch's if they're anywhere even close to the same money as direct replacements. if they're alot more pricey it'll be tough for me to put more money than i need to into a motor i'm not happy with in the car anyways.
the only reason i haven't tried to swap a motor is because i live in apartments. i plan on getting a house next year and then................
Old Oct 22, 2009 | 06:46 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: V6 Injectors
Your '92 RS 3.1l injectors are about 16.5#/hr. They need to measure above 12 ohms each when hot. Any lower then that are shot.
To be honest, if they are the original Multecs, just remove them and toss 'em in the trash can. Then hit up either FIC or LinderTech for replacements in Bosch.
RBob.
Old Oct 23, 2009 | 01:00 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: V6 Injectors
for a V-8 for about what 2 stock replacement injectors cost, you can get a
full set of the remaned bosch 3 injectors.
check out FICs' E-bay store too.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
