can someone identify these injectors
Old Oct 25, 2009 | 09:36 PM
mreld3r's Avatar
Car: 1986 Iroc, 89RS
Engine: 350 tpi, 350 tbi
Transmission: 700r4,700r4
Axle/Gears: 4.10,2.73
I have some ford SVO injectors in my car. I put them in back in 1998.
I "thought" that they were 28lb injectors, but its been a long time and I cant remember. The part number on them is F1TE-D5 and they are blue-top.
At the time I was thinking.
Im installing a 400.
The 305 uses 19lb
The 350 uses 24lb
So the 400 must use 28 or 30 lb.
So I bought a matched set from summit, but I cant remember which ones I bought. Will it matter if I burn a chip? I mean, is there a big difference if I guess wrong? I have an adj. FPR. Will that help if I guess wrong?
I have googled all over, and I cant find that part number.
thanks
Old Oct 25, 2009 | 10:25 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Re: can someone identify these injectors
those blue top's are 24lb injectors, IIRC the 305's came with 19's and the 350's got 22's. If you do not get the injector constants set right on the chip your mixture will be off a fair bit.
Old Oct 25, 2009 | 10:28 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
they are FMS 24 the opposite side should have the bosch # 0280150947.. They are 28 at 58psi.. rated 24 at Ford pressure of 39.15 in your car the constant should be 25.6lb since you will run them at 43.5psi
92-Formula
Dec 12, 2015 10:34 PM
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
