cam and vortec set up
Old Oct 27, 2009 | 04:45 PM
reese_galmon's Avatar
Car: 1990 Firebird Formula 350
Transmission: 700-r4
I'm putting the Vortec Top end kit on my stock 198 engine, I wanted to know if I need to change my stock cam for this set up? If so what cam would be a good swap, I dont want to have to change my lifters and push rods either?
link
http://www.jegs.com/i/GM-Performance...8060K/10002/-1
Old Oct 27, 2009 | 09:35 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
Re: cam and vortec set up
You are aware thats a carb set up, correct?
Old Oct 28, 2009 | 12:32 AM
yea i'm going to put the tpis runners and ported plenum with the setup instead of the carb, I hate carbs
Old Oct 28, 2009 | 07:54 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
The intake manifold coming in the set you linked only works with a carb, it won't work with anything tpi. If you want to go vortec/tpi you need to pick up a set of vortec heads seperately and then a vortec tpi base manifold such as this http://tpiparts.net/inc/sdetail/2944 . There is no vortec tpi/head package sold to my knowledge.
As for a cam, Im not too sure to be honost, from wht I've read though you'll want to make sure the cam has greater than 113 degrees of lobe seperation and don't go overboard on the duration. Im sure somebody else will come around and chime in with a more specific cam. Doing a search on 'l98 cam' would probably turn up some good results too of what people have tried.
Old Oct 28, 2009 | 10:05 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
doing vortec heads, slp runners, vortec base, 1.6 rockers and a gm hot cam would give you 354hp 410tq at the motor..... i read the article and have a very similar combo... the gm hot cam would be a nice cam for your setup..
Old Oct 29, 2009 | 04:52 AM
thanks everybody!
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
bamaboy0323
Sep 3, 2015 06:07 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
