good fuel injector upgrades?
Old Oct 28, 2009 | 11:25 AM
camaroman9191's Avatar
hey guys im lookin to do a engine swap and such with my car but I'd like to know what injectors are the best/ which ones I'll need...Im either doing a 327 or a 383 stroker..both of which will be over 10:1 compression and most deffinitly have a more aggressive cam than stock. I'm having a custom chip burned for it after i figure out the engine size and specs. However ive heard you dont need over 24lb./hr. injectors until you go over 400hp. Is this true? anything helps, Thanks
Old Oct 28, 2009 | 08:28 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: good fuel injector upgrades?
24's sound like the right size.. especially if you have steel heads. get Bosch 3's from FIC www.fuelinjectorconnection.com under 200 for a whole set
Old Oct 30, 2009 | 01:15 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i bought ford 24lbs inhectors for my 355. these work really good and are a direct bolt on part no mods needed. what you could do is get a wideband guage and play with the fuel pressure theres a chart that shows flow rates from injectors size and fuel psi thats def where i would start.
bryan623
Mar 22, 2021 06:43 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
