TPI harness, need to identify to sell
Old Oct 28, 2009 | 08:06 PM
CG002's Avatar
Hi All,
I've done a few searches but, either I'm not hitting the right keywords or the answer is right in front of me and I am missing it.
I've got a TPI harness that I picked up at a swap meet mid 90's maybe. At the time I had a '82 crossfire z with a modified 350 that was carbed. I was intending to do a TPI swap. Never happened. Sold the car at some point and moved on. I've been going through the parts I had accumulated over the years for different projects and stumbled upon the harness. Didn't think I still had it around.
I'd like some help identifying the harness so I can accurately list what it is to put it up for sale. I'd like to see someone else put it to use.
It appears to be a new harness that was never installed in a car. The main connector and a few others have bags over them. I can see a silver writing on the injector connectors (1-8). It has some tape wrapped around it with what may be part numbers but, Google isn't being my friend, so I haven't had any luck.
Here's the numbers:
White Tape: 3626
Orange Tape: 14
Label
12083626 F (maybe E?)
5554 4 90(typed vertically 0 over 9)269
PED 48541
Any help is greatly appreciated.
Chris
If pictures help, I can try to take some tomorrow or Friday.
Old Oct 29, 2009 | 09:39 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: TPI harness, need to identify to sell
Well i dont know about anything with the numbers but heres how i would figure out what youve got:
1. How many injector connectors are there? All TPIs had the 8 injectors but only the 85-88s had provisions for the 9th cold start injector.
2. MAF or MAP connection? MAF covers 85-89 MAP covers 90-92.
3. Connector for MAFS module? 85 only.
Between these facts you should be able to figure out which one you have. the 85, the 86-88, the 89, or the 90-92. I believe that covers ever variation of the harness.
Old Oct 29, 2009 | 09:47 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Also, if you can make out what side of the engine the A/C compressor is wired for, that might help. From 85 to 87, TPI used v-belts, and had the A/C on the driver side. From 88-92, a serpentine setup was used, and moved the A/C to the passenger side.
MantyZ28
16
Dec 21, 2015 11:02 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
Firechicken86
Aug 12, 2015 10:07 PM
mcgarnicle
Aug 12, 2015 04:58 PM
Sanjay
Aug 12, 2015 03:41 PM
