building 383 with stock tpi.. Head cam choice help
Car: 88 GTA
Axle/Gears: 3.27 9bolt
Wondering if anyone has kept the stock intake setup as i dont have enough cash right nw to upgrade it. I just dont know what heads and cam i could go with. i would like to pretty much get the MAX power i can get out of it. A lt1 intake will be in the works as soon as I get a little xtra money. Also what size injectors wuld you run
I would like 400hp and close to 500ft lbs only reson I dont wanan wait till i can get the intake is because i blew my motor and have to get this done now
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: building 383 with stock tpi.. Head cam choice help
1st test here
http://www.compcams.com/Community/Ar...?ID=1737510521
Car: 88 GTA
I knew I had remembered reading that some time ago.. I just reread that whole article and couldnt did see any specifics on the heads. It just says they used trick flow heads???
im guessing maybe these?
http://www.trickflow.com/partdetail....4&autoview=sku
there $1500 from summit complete
Car: 82 Z28
Transmission: T400
Doesn't say they are anything special ; could be the regular 195's for $1000
http://www.summitracing.com/parts/TFS-30400001/
They worked well on my 383 with both TPI ( rev limited obviously ) and HSR
Car: 88 GTA
holy crap thats cheap.. those are complete heads!! geez maybe i can do a intake
Car: 82 Z28
Transmission: T400
