car smokes on startup, want heads
Car: 87 iroc-z
Engine: LB9 305 tpi
Transmission: t5
Axle/Gears: 9bolt BW 3.45 (G92)
stock 87 tpi iroc, valve guides/seals are shot so i was thinking of getting new heads. this is a daily driver looking for some more power. im open for additional mods, not all out tho.
i wanna go with bottom end power on the heads, especialy considering its tpi. i lost bottom end power from the borla cat back install.
- is there any other recommendations/advice for the head section so everything works properly?
- am i gonna have to get bigger runners for the tpi setup?
- what parts need to be machined to match heads
- i saw a edelbrock head with egr valve, does this mean the smog system will still be functional?
before i fix the valve problem, i will be adding shorty headers, mac ypipe, 3 inch cat, new suspension/bushings. existing 3inch borla cat back
please post your thoughts, thanks
