Trick Flow TFS-30410007 $668 or $1299
Trick Flow TFS-30410007 $668 or $1299.
I just looked on Summit and compared two 0007 heads for an 88 350 Camaro.
The only difference I could find is that one is with the CARB number the other is not. Of course the CARB heads are more expensive.
Do I need to worry about the CARB Number or is there a difference I am missing?
All advice is appreciated. There is more knowledge here than I will ever have on my own.
Guest
Posts: n/a
Re: Trick Flow TFS-30410007 $668 or $1299
Yes, the part in the description that says Each. 668*2=1336
I dont know what other difference you may see. CARB number or not doesnt make a difference if you do not have to have it where you are. Might check to see if the cc's are the same, same size valves, springs, etc. They probably have different options available.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
One is for a price for single non CARB# head and the other is for a
PAIR of CARB# heads
single CNC 195 non CARB #
http://www.summitracing.com/parts/TFS-30410007/
single CNC 195 CARB #
http://www.summitracing.com/parts/TFS-30410007-M64/
Pair CNC 195 CARB #
http://www.summitracing.com/parts/TFS-30400007/
There is a $108 ea difference on the CARB head
Thanks guys, I was seeing the 1 in the box and not the sold as a pair.
Call Summit and ask for a commission...you just sold a pair of heads.
I've just visited this forum. Happy to get acquainted with you. Thanks.
Pac J
May 17, 2020 10:44 AM
