swaping 96 vortec 350 for my l98
Old Nov 3, 2009 | 09:04 PM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
l98 is blown... found a good deal on a vortec truck motor that runs good..
My question is will I see much of an improvement in this motor as far as Hp/Tq goes? I knows its only rated at 10more Hp but that is with the truck intake and not the Tpi intake.
Also, what would be the largest cam i could use with the stock vortec heads?
Old Nov 3, 2009 | 10:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: swaping 96 vortec 350 for my l98
Vortec heads require special Vortec base to run TPI
Vortec heads are good for .470 lift unless you change the springs and retainers or machine valve guides for more retainer clearance
Old Nov 4, 2009 | 04:59 AM
wannafbody's Avatar
Car: 88 GTA
im ordering the SD vortec base.
Has anyone used the tool that comp cams makes to machine the heads with your drill?
Old Nov 4, 2009 | 06:26 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Easier to swap the springs and retainers
https://www.thirdgen.org/forums/tech...ortec-lt4.html
MustangBeater20
Oct 29, 2022 09:20 PM
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Aug 31, 2015 06:04 PM
Eric-86sc
Aug 24, 2015 09:01 PM
