chip question
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
Re: chip question
It should, same ecm, practically the same engine running under the same parameters. I see no reason it wouldn't work. I guess the '88 has a tiny bit more cam and flow but Id imagine hyperchips are 'generic' enough where they didn't fine tune them enough for those small changes to matter.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1987 pontiac trans-am
Engine: 350 tpi
Axle/Gears: 3;73 with eaton lsd
all hype and no tech!
