*** Error Codes 43 & 54 *** How do it get rid of them ??
Old Nov 14, 2009 | 09:05 AM
Hole-Shot's Avatar
Car: 85 vette
Engine: 383 stroker
Transmission: zf6 black tag
Axle/Gears: 4:11
I am some error code issues. The main one is code 43 (Low voltage at electronic spark timing circuit). I replaced the module in the distributor, but I still get the code 43.
I also get an occasional code 54 (Low voltage at fuel pump OR Low voltage at Fuel pump relay OR Output failure at quad driver module). This error code comes and goes.
The ecm is a 1990 f-body (7730) with a custom chip.
I need some direction as to possible fixes for this.
Thanks in advance for any help!
Old Nov 22, 2009 | 04:47 PM
BOWTYE8's Avatar
Re: *** Error Codes 43 & 54 *** How do it get rid of them ??
Haha Dave,
I did a search here for code 43 and you popped up first.
Give more details. Have your burned a new chip lately or???
a few threads that came up.
https://www.thirdgen.org/forums/dfi-...code-43-a.html
Maybe someone can help with the pinout. I think a wire goes diecrtly from the ecm to the knock sensor.( But in your case it will goto that plug with the jumper from the old 85 esc ckt. Overall should be a direct run from the ecm to hte knock sensor. You need to verify this.
I dont remember the pinout for the 7730.
Maybe somehere can post it.
Old Nov 22, 2009 | 05:11 PM
BOWTYE8's Avatar
ftp://ftp.diy-efi.org/pub/gmecm/manuals/1227730/
This should help. Save to desktop. pick 92-7730. About 5 files/jpg's
Updated my sig. Currently vetteless. Dont have the 85
Old Nov 22, 2009 | 06:33 PM
Hole-Shot's Avatar
Car: 85 vette
Engine: 383 stroker
Axle/Gears: 4:11
Thanks a lot for the info Dennis. I really appreciate it.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
indygene
Sep 26, 2015 11:21 AM
Lmancha96
Sep 25, 2015 08:11 PM
BWilcox
Sep 20, 2015 12:19 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
