Keep going through FPR diaphragms
Old Nov 14, 2009 | 01:35 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Transmission: 700 R4
Axle/Gears: 370 BW
WTF!! I keep having to replace the diaphragms in my FPR (gas pours out of vacuum line). I had a BBK AFPR and went through two diaphragms. I then installed a Holley AFPR and am going on my third, with less than 1K miles on it. Before installing the last one I filed the inner edges thinking it might be rubbing. I was obviously wrong. The leaks are around the center ring, it looks like it stretches and finally pulls out from around the ring (metal center piece). Any ideas of what could be causing this?
Thank you for any input.
Old Nov 14, 2009 | 07:13 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: Keep going through FPR diaphragms
I had a Holley and it did the same thing. After replacing the diaphragm 3 times I gave up and bought a Crane AFPR. It uses a stock FPR diaphragm, and did not leak, but mine won't adjust to any level lower than 50psi.
Old Nov 15, 2009 | 08:33 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
plugged return line. The way out pressure regulator system works is the pump produces a large amount of unregulated pressure and its the pressure regulators job to bring it down to an appropriate level. It does this by bleeding off some pressure back to the tank. however if the return line is blocked it han no where to go but through the fuel pressure diaphram.
Reid Fleming
Oct 10, 2015 09:56 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
mike22115
Sep 28, 2015 04:49 AM
Lmancha96
Sep 25, 2015 08:11 PM
Strick1
Sep 4, 2015 07:11 AM
