thinking about switching to tpi any suggestions
Old Nov 17, 2009 | 10:58 AM
charlielamb's Avatar
Car: 1991 formula
Engine: 350 tbi
Axle/Gears: 308 posi
so i just put a 350 tbi in my car and i still want more power, so i have decided i will switch to tpi in the next year when i get the money to buy a setup. so my questions are what type of injectors can i use? computer? fuel pump? wiring harness? also is there any free tricks to get more power out of the tpi setup? i know there are budget tbi tricks but are there any for tpi?
Old Nov 18, 2009 | 11:59 AM
Car: 1991 formula
Engine: 350 tbi
Re: thinking about switching to tpi any suggestions
no one can help me out?
Old Nov 18, 2009 | 12:09 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
well you need a wiring harness. you can get one through summitracing.com . The Tpi intake- you can get that over craigs list or ebay CHEAP. need a few 20 dollar sensors. a computer with custom chip.Theres two systems of TPI. SPeed Density and Mass Air flow. I would make it a MAss air flow system better response. tons of power adding "free techniques" can be done with tpi. eight 24# injectors with a high output pump. But Mainly first id get a Intake manifold and plenum first. then harness/computer then sensors then extra needed stuff. my opinion only. I got TPI with 19# injector rated 10% more richer fuel 5.0L also Mass air flow.
Old Nov 18, 2009 | 10:59 PM
Car: 1991 formula
Engine: 350 tbi
what years had the speed density and what years had MAF?
92camaroJoe
Jul 29, 2023 07:57 PM
midge54
Jan 29, 2017 07:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
