Quick Fuel Pump Question
Old Nov 18, 2009 | 02:02 PM
What?'s Avatar
Car: 98 Z 28/89 L98 Formula
Engine: ls1/Undecided
Transmission: 4L60e/Undecided
Axle/Gears: 3.23/Dunno?
Ok. So I just bought a 89 Formula, and am in the process of tearing it down and building it back up. When I tore out the interior, I noticed that the previous owner had done the cut above the fuel pump technique. This was not new to me, what was new was this.
As you can see those lines have been caped with a rubber hose. My question is what are these lines for, and why would someone do that? I am going to switch the car to carb, so maybe this will be beneficial?
Heres what the fuel lines look like in the engine bay.
Old Nov 18, 2009 | 02:57 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: Quick Fuel Pump Question
One of those lines goes to the charcoal canister thingy, the other is for the fuel tank pressure relief check valve, not sure that is the proper name for it tho.
Old Nov 18, 2009 | 03:21 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
My best guess would be they were going to put a carb on it and either use the stock pump with an external fuel pressure regulator, or maybe they tried to set it up to pull through the pump, or possibly fabbed some kind of pickup in the tank and use an external fuel pump.
I'd pull the sending unit and take a look at it. Why not take a look and see what you have, they already hacked the floor up. You can't do any more damage at this point to the floor.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
