broken fuel line
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
broken fuel line
rubber fuel line under the hood broke off the fitting.I`ve been thinking about swapping over to a braided SS line any way.Am I correct in thinking the feed line is the largest of the 2?Is this what I need to make the SS lines work?http://www.summitracing.com/parts/SUM-220009/
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Re: broken fuel line
I forgot about this thread and just ran back across it.I thought Id offer up another option for people that I used.I took my hoses to a localindustrial hydraulic line place and had them make me some SS lines that would fit the stock fittings.Cost me like $45.00 and was done in a day instead of ordering from summit and paying more for all the fittings.Just a heads up if you ever need to do this because you cant buy the replacement rubber lines AFAIK.
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
