411 pcm swap tpi/t5
Old Dec 4, 2009 | 08:55 PM
85SS/85GN's Avatar
411 pcm swap tpi/t5
hi
im looking to do a tpi swap into my 1985 monte carlo ss.i motor needs to be replaced so i have a vortec 350 long block and most of the tpi.the car has a t5 from a camaro in it already so i would like to keep it for now. so my question is can i keep the t5 with the 411 pcm swap?
Old Dec 5, 2009 | 06:15 AM
S10Wildside's Avatar
Re: 411 pcm swap tpi/t5
Yes you can. The PCM doesn't care much about a manual transmission.
If using a distributor application
Load an 01-02 Express Van calibration and disable the 4L60E/4L80E DTCs that will appear.
If using a coil per cylinder application
Load a calibration from a Camaro/Firebird with manual transmission and disable any reverse lockout or skip shift DTCs that appear.
sweet_87_iroc
Sep 25, 2015 10:01 PM
Bstrang6
Sep 8, 2015 04:29 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
