383 12.5 to 1 compression?
Old Dec 5, 2009 | 09:55 AM
355_L98_GTA's Avatar
Car: 1984 TA
Engine: 355 Carb
Transmission: 700r4 Built 2200 stall
I have seen people running 12.5 to 1 with aluminum heads. Just wondering if it will work with 94 octane and a comp xfi 280hr. The compression ratio calculator said it would have about 197psi of cranking compression.
Old Dec 5, 2009 | 04:05 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 383 12.5 to 1 compression?
Have you done a DCR Calc ?
That is a better indication of whether it will knock
Download calc at bottom of page
http://members.uia.net/pkelley2/DynamicCR.html
Old Dec 6, 2009 | 06:01 PM
Car: 1984 TA
Engine: 355 Carb
I'm Just gonna mix 110 with it. I figure with about 100 octane I should be okay.
Old Dec 11, 2009 | 03:29 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
i know 12.1 is fine on the street with alum heads and a Good tune.
with 94 octane..and EFI.
remember EFI.Good Gas(94 and up). Good tune.. not putting 100 miles a day on it..
you should be fine..
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
