Can a LT1 Intake be converted for a vortec styl head?
Old Dec 11, 2009 | 11:09 PM
Prostreet87Z's Avatar
Car: 1987 Camaro Iroc-Z
Engine: 5.7L 350 TPI
Transmission: Manual Valve body TH 350
i have been stuck in a battle between carb and tpi just to use my vortec heads. vortec base plate costs so much i might as well go with a vortec HSR but no one sells them used and carb is a bit riskey due to emissions even though my plates are from michigan i live in arizona i think the cops might still look. the only cheaper option i can see instead of buying a used vortec setup is to possibly get the LT1 style intake machined to fit the angle of my vortec heads and get holes drilled. is it possible to get the angle cut in the intake for the heads?
Old Dec 12, 2009 | 12:12 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Can a LT1 Intake be converted for a vortec styl head?
Vortecs are regular SBC 23 degree heads.The problem is with the shape of the port.
Vortec ports are much taller than regular heads which the LT1 has
LT4 intake with the raised ports might fit but they are more expensive than a HSR
Been several for sale on 3rd GEN this year
https://www.thirdgen.org/forums/engi...rbo-eagle.html
Old Dec 12, 2009 | 09:52 AM
i have always been told vortec headsand the edelbrock etec heads run at a different angle?
Old Dec 12, 2009 | 03:39 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The hold down bolts ( have only 4 not 6 like reg heads) have a different angle
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Fast355
Dec 2, 2016 06:33 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
