IAC Problems
Old Dec 16, 2009 | 05:46 PM
Matemk's Avatar
IAC Problems
Motor is 1988, Car is 1990.
There is a different Computer and IAC in the 1988 than there was in the 1990.
I am having a sealing problem with the IAC to where it is causing a vacuum leak through it, would having a 90 computer and an 88 IAC have anything to do with this?
seems like i can not get the IAC to extend unless i put the car into default mode, even then when i can hear it extend it still has the leak.
btw its not a sealing issue where it screws into the TB, its where the cone head meets the air passage.
Please Help
Old Dec 19, 2009 | 12:29 PM
Matemk's Avatar
Re: IAC Problems
anyone have an idea on this?
If an 88 TPI Motor got dropped into a 90 Camaro, MAF Removed and MAP Added, what sensors need to be changed?
i know the knock sensor is different, what about TPS, 02 sensor, IAC,
Need Help On This, would like to get it running.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Sep 4, 2015 07:57 AM
greenyone
Sep 2, 2015 03:39 PM
86IROC112
Aug 21, 2015 07:20 PM
