help car idles at 3k
Old Dec 23, 2009 | 02:36 PM
patricksmithahh's Avatar
Car: 90 corvette
Engine: l98
Transmission: built 700
Axle/Gears: stock
1990 corvette 350 tpi ..i just did my intake manifold gaskets put everything back together and my car is hard to start and when it does the idle shoots up to 3000+ rpms
what could cause this it was running fine prior...
Old Dec 23, 2009 | 03:48 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
Re: help car idles at 3k
could the problem be cause by my iac...i did the coolant bypass and i didnt plug the holes that i cut where the hoses ran to also and i didnt put the gasket back in cause i figured it didnt need it could that be messing with the iac in any way?
Old Dec 23, 2009 | 06:29 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
If you're talking about the gasket that is between the bottom of the TB and the IAC housing then yes that may be the problem...
What holes did you cut and where?
Old Dec 23, 2009 | 09:58 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
the tubes that the coolant hoses connect to is where i cut..trhe problem is fixed and that was what fixed it
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
