stand alone tpi? this will trip u out!
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: stand alone tpi? this will trip u out!
first off in this state we have no inspection, no emission testing and i gave him a 100 bux for the car, no emissions: no smog, no mufflers, hell open exhaust if you want, and u can think what u want, i just stated what the car was doing when i had it, and the fluke i found in the ecm and wiring, u can all say bs if you want, cause i dont have the 'McGyvered' wiring on the car and if i had even been on this site at the time i would have took pics and videos, yes the stock guages are known for being a lil off, i was 17 and in highschool at the time, i kept it clean and tuned it up, the only mods i ever did were k & n's a flowmaster, and gutted the airbox.
i appreciated the INTELLEGENT comments and criticism, after joining this site a few years ago, i talked to ppl like traxion, and quite a few others who KNOW what they are talking about and finally understood how the tpi system works,
when i have a question: this is the first site i search or create a thread on,because most of the 3rd gen owners on this site are very helpful
Kudos to them!! to anyone who badmouths another member...
know what your talkin about before you blurt out "thats BS!"
i have no reason to lie just to impress any of you, theres lots of sick@$$ fast cars on here, if you didnt know how to work on your cars, when they break down youd all be drivin new mustangs,lol were all on here to post, learn and share info gentlemen
know what your talkin about before you blurt out "thats BS!",
I agree, You yourself should know what your typing, not talking, before you try to sound INTELLIGENT.
Your not so intelligent yoursef foo. Look how you spelled the word. You spelled intelligent wrong
. Agian, you should proof read before you hit "submit reply." I have to do this agian Hotrod85z, you are
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
chevy86, you spelled again agian......lol, sorry just thought that was funny, you were talking about spelling errors.....lol.
I do agree with you though, post are kinda out there....
With all the posts, and discussion about this over the last two or three weeks, proof is in the initial post. There is no way the valve train of a stock 305TPI is gonna spin to 6500/6700 RPM, and 70 MPH in first gear of a TH700R4. Did I mention the likelyhood of his 0-60 in 5.0 seconds being legit? nil.
Signed,
Another long time member with less than 200 posts.
Signed,
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Chevy86, If you're willing to learn, and you have - as you say - after a few years since that car - learned how the TPI works.
Then you must admit that no matter how hacked the car was, it would not, could not, run without the ECM. If it was running, again, regardless of how good/bad it was running, it was under ECM control, limp home mode isn't stand alone, it's just fixed settings that will allow the ECM to run the engine within a given afr/rpm range. If the ECM is for all practical purposes dead the engine will not run, period. To clarify - by run I mean idle, much less beat a another stock 305 TPI, let alone a L98, or LT1.
If that has any BS point it out.
So if you know all this why the title "Stand Alone TPI?" adding the question marks shows without a doubt that you doubt your own knowledge.
You know how a Tuned Port intake system works, so unless you modify it it's not going to grow a mind of it's own and operate outside it's OEM design parameters, you did not have a "Herbie", or "Johnny 5", or an "Andrew Martin."
You say you appreciated intelligent comments and criticism.
Here's my only criticism.
Having possessed such a one of a kind, stang, L98, and LT1 killing 305 TPI you did nothing to document its electrical, electronic, and mechanical state? To possibly recreate it, to prove you had an anomaly, a bumble bee as it were (engineers say it shouldn't fly, but the bee doesn't know that.)
Even after years of learning how TPI works - You chose the following words to make your statement:
"...the non ecm controlled tpi 305 wouldve eat the new motors ***" This to me is the only BS on this thread.
And, I'll tell you why I say it, 3 letters, TPI. If you would have left those 3 letters out it would be pausible.
I wouldn't bat an eye if someone said, "my non ecm controlled 305 can eat your newer TPI motor." Yea, I can believe that.
Damb, you got me good manAtleast I'm admitting my mistake.
For a long time I've been writing again incorrectly. Atleast I know what I'm typing about. Anyone wanna check my punctuation?
Car: 88' IROCZ
Axle/Gears: 2.77
Car: 85 vette
Engine: 427 SHP block,AFR 210,MiniRam
Transmission: TKO 600
Axle/Gears: 3:07
I am impressed how many different ways it can be explained that fuel injectors need to be turned on and off by something other than the ignition switch.
Cut and paste will throw you under the bus when you dont expect it. No problem, I accept you apology rgarcia63. I think Im done with hotrod85z. He really is full of it. He's just trying to bring attention to himself. Forget that little kid. I already have. Thread
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
Sanjay
Aug 12, 2015 03:41 PM
