TPI Starter question
Old Dec 28, 2009 | 02:05 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Hey all,
The starter on L98 is about to die completely, and I was looking into getting a high torque mini starter. Anyone have any experience with them?
The one that I was eyeing up is this one: http://www.summitracing.com/parts/SUM-829100/
Are they worth it? What is a good one for around that price? (less than 150)
Thanks in advance!
-Tim-
Old Dec 28, 2009 | 06:53 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: TPI Starter question
I bought an LT1 starter off ebay.
Fit perfect and worked great.
Old Dec 29, 2009 | 01:22 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The late Vette L98 Denso mini starters crank good.
http://cgi.ebay.com/ebaymotors/NEW-S...Q5fAccessories
Old Dec 29, 2009 | 07:43 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I'm using the Summit Protorque mini starter and love it. No more slow cranking hot starts and I think it sounds better than a stock starter. I've also heard good things about the LT1 starter if you're looking to save a couple bucks.
Old Dec 29, 2009 | 10:17 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Tim, just get an LT1 starter and don't look back.
Old Dec 29, 2009 | 01:04 PM
Car: 1991 Camaro RS
Engine: L98 350 TPI
This may be a dumb question, but what makes the LT1 starter better than the TPI/mini starter?
Old Dec 29, 2009 | 01:28 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I picked up a Denso version at a local yard. Works great with only one exception. I run Hedman Longtubes and need to smack the pass side with a hammer just for a little more clearance.
Old Jan 2, 2010 | 11:11 AM
Dyno Don's Avatar
It's GM.....more compatable.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
milk
Aug 10, 2015 06:26 PM
