Ignition Coil Primary Wires
Old Jan 5, 2010 | 03:11 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Real easy question, but I can't seem to find a solid answer anywhere.
'85 305 TPI. Are the coil primary wires supposed to be red and white or red and yellow?
Old Jan 6, 2010 | 09:00 AM
88gta_hiflyer's Avatar
Car: 1988 GTA
Engine: 305 tpi (LB9)
Transmission: WC T-5
Axle/Gears: 3.45 posi
Re: Ignition Coil Primary Wires
I assume you're talking about the wires that connect to the top of the coil with plastic connectors. If so they should be red and white.
Old Jan 6, 2010 | 09:09 AM
Car: 1985 Z28
I have an HEI in-cap coil.
I am referring to the two primary wires that come out of the coil itself.
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
92camaroJoe
Aug 13, 2015 06:07 AM
92projectcamaro
Aug 6, 2015 01:20 PM
