Fuel Rail Issue
Old Jan 11, 2010 | 02:28 PM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Fuel Rail Issue
Guys - Have been chasing a cold number 8 cylinder. Done the basic checks for spark, I want to check fuel now. Has anyone seen a plugged fuel rail that would block fuel to 1 cylinder? What about checking to see if the spark plug is receiving signal from the harness wire?
Old Jan 11, 2010 | 04:32 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: Fuel Rail Issue
i assume u mean injector as far as recieving a signal. i can't remember the voltage to look for as far as checking your injectors. one test you could do is start the car and then touch the injectors, you should beable to feel it pulse, then you will know its working or not working
Old Jan 11, 2010 | 04:58 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Fuel Rail Issue
Automotive stethoscope or a long screwdriver touched to the injector and your ear at the other end will tell you if the injector is pulsing. IIRC the voltage should be 5v.
It's unlikely but possible that the intake screen on the injector is plugged.
Old Jan 12, 2010 | 08:24 AM
Car: 1987 Iroc-z
Re: Fuel Rail Issue
Thanks for the replies, I will try some ideas in the spring, car is in storage. Injectors are new Fords, swapped out new Accels as a possible culprit. Sad thing is that most everything on my set-up is new. Not the wiring harness though. I know new parts can be bad, I have checked a bunch of ignition parts, timing etc.
Frozer!!!
Jan 19, 2024 04:55 PM
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
