Please help!! L98 knocking when warm, i have replaced EVERYTHING!
Old Jan 15, 2010 | 12:00 PM
88TPIZ's Avatar
Car: 88 IROC Z/ 92 Z28
Engine: L89/L89
Transmission: 700r4/700r4
Axle/Gears: 9 bolt/9 bolt
I can not figure out what is wrong with my '91 z28. It is an l98 with 129,000 miles. It has a new fuel pump and filter, o2 sensor, plug wire rotor cap. ecm, tps, icm, coil, i tested the converters, thermostat, radiator, fans are working, cant find any vacum leaks, good fuel pressure .
here is what it is doing.
It will start and idle fine but once it warms up and i start to drive it will starts to knock and when i put the pedle to the floor it will stay at 2000 rpms and knock like crazy, however when it is in neutral or park i can rev it as high as i want. When the engine is cold it drives fine, it only acts up when is warms up.
It finally gave me a code 32 so I replaced the egr valve, still no change.
Please help me, the rest of the car is too nice to not be able to drive.
Old Jan 15, 2010 | 12:02 PM
NY3RDGEN's Avatar
Car: Trans Am, Corvette
Engine: LB9, LT1
Transmission: 700R4, 4L60
Axle/Gears: 373, 259
Re: Please help!! L98 knocking when warm, i have replaced EVERYTHING!
Sounds like the cat, i see u tested them. But i would double check that. IMO anyways.
Old Jan 15, 2010 | 12:17 PM
Glenno's Avatar
Car: 1990 Jeep YJ
Engine: 70's 350 w/87 Z TPI-MAP Conversion
Transmission: Muncie SM 465 Granny Low 1st
Axle/Gears: 4:10 Gears in both axles
Did you convert from a MAF to a MAP system? If so the knock sensors are different. Keep us posted. Good luck
Old Jan 15, 2010 | 12:51 PM
88TPIZ's Avatar
Engine: L89/L89
I am positive the cats are good. I have not changed the map system.
Old Jul 16, 2012 | 01:28 AM
marrober9's Avatar
I have a Vette doing the same exact thing did you ever get this resolved? Thanks
Old Jul 16, 2012 | 04:12 AM
Jeffs82TA's Avatar
disconnect the ecm's control over timing, if that stops it from doing that then it is either the internal ecm est module or knock sensor.
Old Jul 16, 2012 | 07:09 AM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
How's your oil pressure?
Old Jul 16, 2012 | 10:12 AM
88TPIZ's Avatar
Engine: L89/L89
Ok I got it fixed and its running great. The problem was the intake manifold gaskets were rotten and leaking air, it was backfiring through the throttle body and that was the 'knocking' I was hearing. While I had the intake apart I replaced the injectors too.
Vintageracer
Jan 10, 2020 05:33 PM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
gwade12
Aug 8, 2015 08:17 AM
