tps problem
Car: 90 formula
Transmission: auto
tps problem
okay so ive been getting code 23 - error from tps. i replaced it and the bird sounds better but when accelerating i still get the code to come on.
anybody else have this problem?
i have no clue where to go next
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: tps problem
The best way to find out if the TPS is the culprit is to bunny some jumpers
and use a voltometer like in the TPS FAQ. Instead of just setting it and
bolting it up tight.. Carefully increase/decrease the arm on the TPS and
watch for sudden jumps or stalls in the TPS voltage reading at the meter.
If the readings are highly irregular & inconsistent, then that TPS is funky.
Since you replaced it, id check out the wiring for damage as well,
Since the code triggers upon acceleration, id want to say something
electronic might be going on the fritz
Hope you get it solved.
Car: 90 formula
Transmission: auto
Re: tps problem
did my research to find the code also goes on for the sencer in the intake and i noticed its unplugged with a broken connector.
Re: tps problem
Code 23 is the Intake air temp (IAT) ..not TPS related. It is kind of a
pain to get to the sensor, not as easy as some of the others anyway.
So were you getting codes 22 & 23? or just 23?
Code 22 is TPS related, I didnt catch it earlier, and could have said
something earlier! ..Where did the idea about a TPS issue come from?
Hope it works out! That would be very cool.
Car: 90 formula
Transmission: auto
Re: tps problem
both 22 and 23 and the error code page said it could be error from tps
but yeah that sensor isn't plugged in and the reason for the code.
92camaroJoe
Aug 13, 2015 06:07 AM
