906 or 060 heads with tpis big mouth
Old Jan 22, 2010 | 10:31 AM
leek157's Avatar
Car: 95 SHO. 87 IROC red 69 Vette blue
Engine: 3.0 Yamahammer.5.7 TPI L98, 350
Transmission: mtx4 ,700r4, 4speed,
Axle/Gears: 3.27, 3.73
I know a stock tpi base wont work with vortec heads but will the tpis big mouth work on a set of 906 vortec heads?
Old Jan 27, 2010 | 07:18 AM
Pat Hall's Avatar
Re: 906 or 060 heads with tpis big mouth
The last time I bothered to check, the only TPI intake I know of that'll work with the Vortec heads is the Scoggin-Dickey one that's specifically made for TPI w/Vortecs. I think you meant to say 062 heads, which is the other Vortec casting, and their ports are setup exactly the same as the 906's. If TPIS started making a Vortec TPI intake, it's news to me.
Old Jan 31, 2010 | 07:40 PM
IAGTA's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 w/SLP cold air intake
Axle/Gears: 9 Bolt 3.27 with PBR brake upgrade
According to the TPIS web site, they do offer an option to use the MiniRam on Vortec heads although the heads will have to be drilled for the standard Chevy manifold bolt pattern.
Fast355
Dec 2, 2016 06:33 PM
gta90
Sep 15, 2015 04:00 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
