Question about TPI Heads
Old Jan 23, 2010 | 12:52 PM
S_Johnson's Avatar
Car: 87 T/A
Engine: 400SBC Carb'd
Transmission: T56, Kevlar clutch
Axle/Gears: 3.73 Yukon Duragrip posi
Ok, so I'm selling my TPI stuff from my 305, and someone with a 350 want's to know if it will fit, What years of heads will work? I know I've seen this before, but I couldn't find it. Thanks Guys.
Old Jan 23, 2010 | 06:37 PM
S_Johnson's Avatar
Car: 87 T/A
Re: Question about TPI Heads
I know about the tuning that would need to be done, I'm just talking about physically bolting up.
Old Jan 23, 2010 | 07:50 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
305 heads on a 350 block will increase compression which will give a little more horse power but, you'll run the risk of detenation. For example, a 86 305 block will have of course 305 heads. TPI heads have the same dementions as anyother chevy heads. The one big difference would be that truck heads have a swirl intake ramp which increases torque at low RPM's (for hauling heavy loads). Now if you port and polish some swirl intake heads, you can get some decent gains. But you still have to remember that the TPI intake such as the runners restrict airflow meaning that there is a loss of power..
Old Jan 23, 2010 | 07:52 PM
As for bolting up, yes the bolt pattern all lines up. The difference between the 305 TPI heads and the TPI 350 heads are that the combustion chamber will be smaller and will also be raising the compression.
Old Jan 23, 2010 | 08:01 PM
S_Johnson's Avatar
Car: 87 T/A
No, I'm asking if my TPI INTAKE MANIFOLD will fit onto other years of heads.
Old Jan 23, 2010 | 08:02 PM
S_Johnson's Avatar
Car: 87 T/A
this guy has an already done 350, that he wants to make TPI with my TPI stuff, He doesn't want to use my heads I don't think.
Old Jan 23, 2010 | 08:05 PM
Dont yell at me foo. Im right here. I can hear you fine (technically speaking while typing). Yes it'll fit. I think its just like 8 bolts. Becarefull. Dont drop a mounting bolt into the heads.
Old Jan 23, 2010 | 08:06 PM
Besides, where did you ask if the TPI Intake would fit? "Ok, so I'm selling my TPI stuff from my 305, and someone with a 350 want's to know if it will fit, What years of heads will work? I know I've seen this before, but I couldn't find it. Thanks Guys. "
Old Jan 23, 2010 | 08:08 PM
Did he ask you to ask this question? I ask because the system is already his right. So are you just doing him the favor?
Old Jan 23, 2010 | 08:15 PM
Im not sure if the intake will work on vortec heads. Anyone wanna take a shot to answer this question?
MustangBeater20
Oct 29, 2022 09:20 PM
gta90
Sep 15, 2015 04:00 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
