Water Damage
Old Feb 2, 2010 | 11:48 PM
Grants89iroc-z's Avatar
Car: 1989 Chevrolet Camaro iroc-z
Engine: 350 Tpi
Transmission: t5 Tranny
Axle/Gears: 3.08
Water Damage
Engine seized after getting water in engine, Took out all spark plugs and water poured out of Cyl. #8. Still does not crank over, and starter is good.
My question is, Could i have a bent valve? Also, would that cause my engine to not move at all? I dont see what could make the engine not Move AT ALL. Wont go Backwards, Wont go forwards. Something is stopping this engine from moving, Ideas?
Thanks!
Old Feb 3, 2010 | 12:28 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Water Damage
Bent connecting rod. Water doesn't compress too good.
Old Feb 3, 2010 | 09:06 AM
Engine: 350 Tpi
Axle/Gears: 3.08
Re: Water Damage
Right, but i dont see how a bent rod can stop an engine from moving completely. I cant even spin it backwards
Old Feb 3, 2010 | 09:49 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Re: Water Damage
Depends on how it bent... If it bent the rod sideways when it went, then yeah, you could be hosed pretty good, I would imagine you might not be able to turn it at all...
Old Feb 3, 2010 | 12:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Water Damage
Doesn't really matter what the cause is anyway. If it won't turn, it's time for a new engine.
AaronIROCZ's Avatar
Moderator/TGO Supporter
Re: Water Damage
If the rod is bent you wouldn't be able to turn it over at all. I had a friend who did it to a 82 chevy 4x4 truck and tried to pull it and pop the clutch while in 4wd and it just locked all 4 tires and the engine did not move. He bent 6 out of 8 rods so you may have more than 1 rod bent.
Old Feb 4, 2010 | 06:55 PM
Steve86TA's Avatar
Car: To many to list
Re: Water Damage
Was the engine running at the time it got water in it?
sheachopper
Jul 31, 2019 11:27 AM
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
