maf question
Old Feb 4, 2010 | 04:24 PM
IROC_Z89's Avatar
Car: 89 IROC-Z
Engine: 350 tpi
maf question
I hae a 350 tpi out of an 89 camaro and i want to install a cold air kit but the bulky bosch maf is making it difficult to get a clean look. Can i do anything to eliminate need for maf or i their a kit that works well with it? I see many tpi motors with cold air kits and no maf in site so there must be a way. All help is appreciated. Thanks
Danny
Old Feb 4, 2010 | 05:18 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Re: maf question
I believe u need the maf sensor or ur motor will run like crap...unless its a speed density u need the maf sensor.
Old Feb 4, 2010 | 05:20 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: maf question
The ones you are seeing are '90 -'92 engines with MAP sensor so no MAF sensor on intake.
Would require computer change and some rewiring
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
http://www.s10wildside.com/wildside/ecmandtuning.htm
Old Feb 4, 2010 | 06:05 PM
IROC_Z89's Avatar
Car: 89 IROC-Z
Engine: 350 tpi
Re: maf question
would it be that difficult of a job? does MAP have any pros over MAF
Old Feb 4, 2010 | 06:58 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: maf question
why do you want a cold air intake, you already have one with the stock setup. Cut out the baffles under the air lid, and either build or buy the air boxes from hawks third gen parts. I did that with my car and putting down 476hp and 496tq at the motor. Removing the maf is just to much of a hassle
Old Feb 4, 2010 | 07:29 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: maf question
The full how to with pics is in the links; are you capable?
Old Feb 4, 2010 | 07:53 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: maf question
well a map is cheep thats a +
Mass infinite tuning capabilities very accurate
Old Feb 4, 2010 | 08:20 PM
IROC_Z89's Avatar
Car: 89 IROC-Z
Engine: 350 tpi
Re: maf question
yeah im no expert but i am capable especially with directions how to
chazman
Aug 28, 2018 03:25 PM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
